1994 LS400 vs. 2000 AVALON XLS
Old 02-06-14, 06:14 PM
OMAHA
OMAHA's Avatar
Default 1994 LS400 vs. 2000 AVALON XLS
i have the LS400 and a guy wants to trade straight across for his Avalon.....both cars run fine and both have 200000 miles on them.....is this a good deal?
Old 02-06-14, 06:28 PM
cobalt91
cobalt91's Avatar
I would keep the LS.
Old 02-06-14, 06:51 PM
OMAHA
OMAHA's Avatar
i'm leaning that way.....
Old 02-06-14, 08:27 PM
Gene01
Gene01's Avatar
Hey, are you the one that Manning keeps calling?
Old 02-06-14, 09:14 PM
OMAHA
OMAHA's Avatar
no?...............
Old 02-07-14, 06:19 AM
python
python's Avatar
the 3.0 engines are susceptible to sludge issues if they haven't followed certain guidleines for OCI and correct oil. just letting u know,nice cars but if they haven't been routinely maintained then u just are getting into something u might not want to be getting into. u already know what u have..i would keep your car myself unless urs is trashed...why does he want to trade? something he isn't telling u?
Old 02-07-14, 07:04 AM
Yamae
Yamae's Avatar
I agree with python. He is pointing out important points. The sludge issue is not always the case but that is discussed widely and I wouldn't trade if I were you.
Old 02-07-14, 07:07 AM
OMAHA
OMAHA's Avatar
he wants a rear wheel drive lexus he can modify into a 5 speed....your right, i do know the lexus and its in great condition, cosmetically an mechanically.....except a power steering leak and also possibly a lifter issue......i just did the cam seals,crank seals, timing belt, water pump, thermostat....
Old 02-07-14, 08:20 AM
python
python's Avatar
keep it..end of discussion
Old 02-07-14, 10:30 AM
timmy0tool
timmy0tool's Avatar
not a fair trade at all, esp after you did all that maintenance! the LS will outlast that car at its current mileage.
Old 02-07-14, 11:19 AM
Kingsoup
Kingsoup's Avatar
I don't think the avalon is built to the same quality standard as the LS, but FWD is a lot better in the winter if that is a factor.
Old 02-07-14, 02:10 PM
YoshiMan
YoshiMan's Avatar
Transverse mounted V6s, especially the 1MZ-FE, are horrendously difficult to work on, and have very high labor costs because of this as well.
I know numerous people who own cars with that horrid engine, and they end up shelling out a small fortune for things as small as a bad ignition coil, because it requires you to dismantle half the intake manifold just to get the stupid things out. There has been numerous cases where they come to me asking if i can fix some small problem, which ends up being a significant tear down issue that i am not willing to do on someone's car i barely know.
Just did the belts on a friends wifes RX300, and it was rather unpleasant. Most of the tools couldn't fit between the front of the engine and the frame of the car.
Old 02-07-14, 02:43 PM
OMAHA
OMAHA's Avatar
i actually prefer rear wheel drive.....as well as the V8 over the V6......i was pondering if a Avalon was better car comparing a 2000 vs. 1994 LS400........i had someone tell me (he claims he is a certified Toyota mechanic) that the Avalons are cheaper to work on, however nonetheless, i did install genuine toyota/lexus parts along with toyota red coolant and a full synthetic oil change with bosch filter....
Old 02-08-14, 03:08 AM
VanCityLS4
VanCityLS4's Avatar
I owned & modified a 01' XLS. To sum it up you tell it was built in America. No comparison to chassis or anything on the inside. Mine rode terrible on JIC's. You could really feel the poor 60/40 weight balance even after I added a RSB. The 3L is prone to sludge but I couldn't hate on regular gas & low 20's MPGs all day. Interior was massive & trunk was cavernous.
Old 02-08-14, 03:51 PM
OMAHA
OMAHA's Avatar
hey thanks for the input!
Quick Reply: 1994 LS400 vs. 2000 AVALON XLS
