Timing belt / water pump kits
Old 02-13-14, 10:06 AM
spoogie
spoogie's Avatar
Default Timing belt / water pump kits
There are boatloads of water pump / timing belt kits on eBay. Should I consider any of these or look at something else?
http://www.ebay.com/sch/sis.html?_kw...ump+Kit+GX+470
Old 02-13-14, 11:08 AM
Extreme Dimensions
Former Sponsor
Extreme Dimensions's Avatar
The ones I clicked on don't even say what brand they are.....
When it comes to Timing Belts I only trust Dealer parts or Gates belts. Water pump wise I will only go dealer parts. Remember, these are pretty expensive repairs if you don't do them yourself, and if either fails it can lead to catastrophic failure.
Old 02-13-14, 11:13 AM
cssnms
cssnms's Avatar
Not all parts are created equal - lots of Chinese crap out there.
Aisin makes the water pump etc for Toyota. There is an Amazon seller (ToyoLexus Parts Connection) that sells the complete kit which is the same as you would buy from Toyota. Another member on here has purchased the kit and compared the parts against what was removed from his truck and they are spot on.
This is a very comprehensive kit which includes the serpentine belt and cam seals too.
OEM Aisin TKT-001 Complete Water Pump Kit-Timing Belt : Amazon.com : Automotive OEM Aisin TKT-001 Complete Water Pump Kit-Timing Belt : Amazon.com : Automotive
Old 02-13-14, 12:05 PM
470reasons
470reasons's Avatar
Looks like a decent kit. Mitsuboshi belts are Lexus OEM at least on some Lexus models. Now if it was a Mitsubishi product, no way I'd put it on a Lexus!
Old 02-13-14, 05:23 PM
spoogie
spoogie's Avatar
Good info. Thanks.
What should labor cost?
Old 02-13-14, 05:49 PM
cssnms
cssnms's Avatar
Originally Posted by spoogie
Good info. Thanks.
It depends where you go, but a good indy may charge you anywhere from $300 to $450 labor.
Old 02-13-14, 07:08 PM
spoogie
spoogie's Avatar
Not bad. I'll likely wait until 200-210k miles to do it, but buy the parts now. Thanks.
I also noticed that some come with a hydraulic pump tensioner (no idea what this is). Others come with a thermostat kit. Is it better to buy that way and have it done at the same time?
http://www.ebay.com/itm/AISIN-OEM-TIMING-BELT-WATER-PUMP-KIT-W-HYDRAULIC-TENSIONER-TOYOTA-LEXUS-V8-/261110179012?_trksid=p2054897.l4276
http://www.ebay.com/itm/AISIN-TOYOTA-TUNDRA-4-7L-V8-COMPLETE-TIMING-BELT-WATER-PUMP-HOSE-THERMOSTAT-KIT-/261110186075?_trksid=p2054897.l4276
Old 02-13-14, 08:15 PM
RCsGX
RCsGX's Avatar
Timing belt tensioner....
Old 02-14-14, 05:48 AM
cssnms
cssnms's Avatar
http://www.ebay.com/itm/AISIN-OEM-TI...p2054897.l4276
http://www.ebay.com/itm/AISIN-TOYOTA...p2054897.l4276
How many miles do you have on your GX?
Old 02-14-14, 11:27 AM
spoogie
spoogie's Avatar
172k.The timing belt and water pump was changed at 100k.
Old 02-18-14, 12:57 PM
spoogie
spoogie's Avatar
Does anyone here know if the timing belt tensioner, hoses, and thermostat should be performed at the same time as the water pump and timing belt? This is the second timing belt service on my GX.
Old 02-18-14, 01:22 PM
BradTank
BradTank's Avatar
Personally, I wouldn't buy off of Ebay, there's a lot of counterfeit parts floating around. Someone selling parts out of their garage is a crap shoot, I've personally been scammed where someone sent me a new part in the box and it had clearly been swapped with something different. I'm sure most are legit, but the savings are usually trivial.
I would buy off RockAuto or Amazon, and would buy the Aisin kit with everything (water pump and tensioner). And I would buy new hoses, new thermostat (dealership on T-Stat) and also a new serpentine belt and radiator cap (dealer). It's worth the extra $80 or so, especially with your mileage to just get this out of the way.
I would also inspect your radiator, mine started leaking like many of them do on the lower driver's side.
Old 02-18-14, 02:25 PM
spoogie
spoogie's Avatar
My Radiator was replaced at five years.
Why would you buy those certain parts from the dealer and not as part of a kit or some other discount source?
Old 02-18-14, 03:37 PM
cssnms
cssnms's Avatar
Yes it is recommended, they are cheap parts and while they in there you might as well replace them.
Old 02-18-14, 03:56 PM
BradTank
BradTank's Avatar
At the end of the day, the premium is incredibly small. It's cheap insurance.
An OEM Thermostat is like $12 whereas as an aftermarket is like $7. Some aftermarket thermostats are too universal (not the right temperature) Also, there's just a lot of failures with "AutoZone" quality aftermarket thermostats.
Radiator cap is basically the same concept. Cheap upgrade, not worth the headache to save $3-$4 on a part made in Mexico or China.
Quick Reply: Timing belt / water pump kits
