headlight no turn off
Old 02-15-14, 11:46 PM
richard203
richard203's Avatar
Default headlight no turn off
this morning when i lock my car my headlight turn off but when i get home i lock my car it still on, Any help?
Old 02-16-14, 01:17 AM
dchar
dchar's Avatar
If you press lock twice or touch indent twice, it should turn them off. If too much work, then use settings to change how long they stay on when you get out.
Old 02-16-14, 05:32 AM
rjm
rjm's Avatar
I have the lights set to turn off when I open the driver's door to exit (initial setup). If you don't know how to do it, your dealer can set it up like that for you.
Old 02-16-14, 06:21 AM
Received 2,519 Likes on 1,817 Posts
Are the lights set to "ON" or "AUTO"?
In the 4GS the lights no longer automatically shut off when they are set to "ON" for some inexplicable reason like they did in the old GS300 in your sig...
Old 02-16-14, 07:46 AM
Rexus300
Rexus300's Avatar
Press lock key twice to turn off light.
Old 02-16-14, 12:28 PM
richard203
richard203's Avatar
I know how to use the remote to close the headlight by pressing lock two times. But when I press my lock it don't make any sound but it locks the car and the headlight don't turn off
Old 02-16-14, 12:34 PM
You mean when you press the remote locking button on the door handle? It doesn't turn the lights off, even if you press it twice. They will go off after the elapsed delay period...
Old 02-16-14, 12:43 PM
richard203
richard203's Avatar
When u press twice ur headlight should turn off. I already know if u press 1 time lock and wait 10 sec ur headlight will turn off. My problem is when I press two times it don't turn off and make the beep sound when I lock my car or press the emergency light when lock. The headlight turned to Auto.
Old 02-16-14, 12:53 PM
No. If you press the handle twice the headlights will not turn off. Pushing twice only works on the remote.
Old 02-16-14, 12:54 PM
richard203
richard203's Avatar
Even if I press my remote it don't turn off or make any sound when I lock my car...
Old 02-16-14, 12:57 PM
But it locks all the doors? And the lights do go out after 10 seconds?
Check to be sure the audio for the beeping and make sure that its turned up all the way. There used to be a **** under the drivers side of the dash but I'm not sure nowadays.
Old 02-16-14, 01:06 PM
richard203
richard203's Avatar
When unlock the car it have the sound just when I lock the car it don't have the sound and don't turn off the headlight.
Old 02-16-14, 01:13 PM
Do the doors lock? If they do then do the headlights eventually shut off or do they stay on indefinitely?
Old 02-16-14, 01:19 PM
richard203
richard203's Avatar
I don't think u understand what I'm trying to say...
Old 02-16-14, 01:26 PM
I do understand and I'm trying to help you, but I can't help you if you won't answer my questions.
1. When you try and lock the doors, do the doors lock (I understand there is no sound)? (yes or no)
2. Do the headlights eventually turn off or do they stay on indefinitely? (they eventually turn of or they do not)
If the answers to those questions are 1. Yes and 2. They do not its likely a bad door switch...
Quick Reply: headlight no turn off
