wheel fitment help needed
Old 02-24-14, 03:38 PM
TTurboPimp
TTurboPimp's Avatar
Default wheel fitment help needed
Will these work on an 01 LS430, and if so with what work and tire size?
Im pretty sure im good with the +22's, its the +15's that worry me a bit
19x8.5 +15
19x10 +22
thanks
Old 02-24-14, 04:44 PM
HiloDB1
HiloDB1's Avatar
You're going to at least have to shave the rears and roll the fronts. What size tires are you planing on running?
You may also want to get the longer rear lower arms to add some camber to the rears to help with clearance. The front adjustment should be good for about -3*.
Old 02-24-14, 09:57 PM
SQuester
SQuester's Avatar
You'll be fine if you run 225's and 245's. My previous setup before I rebarreled my rims were 20x9 +22 and 20x10 +23, only rears were shaved and not completely. Camber will be fine with stock arms, just seriously think about higher spring rates for the front(at least 14kg/mm) so you don't damage the arches accidentally.
The 10 +22's will fit more aggressively than the 8.5 +15's.
Old 02-24-14, 10:30 PM
SQuester
SQuester's Avatar
Here's an example of aggressive 19's.
https://www.clublexus.com/forums/ls4...nu-finale.html
His original build thread.
https://www.clublexus.com/forums/sho...902&styleid=13
Old 02-24-14, 10:43 PM
HiloDB1
HiloDB1's Avatar
The 8.5 +15 will be about 0.65mm out from a 10 +22.
Old 02-25-14, 01:14 AM
SQuester
SQuester's Avatar
I'm speaking of rim lip to fender relation, as the front and rear fenders don't correlate. A 10 +22 on the rear is more aggressive than the 8.5 +15 on the front.
Also, 8.5 +15 is basically the same as a 9 +21 without taking tenths of a mm into consideration
RichardB23
11-22-22 10:15 AM
3nergiz3d
IS F (2008-2014)
21
03-09-16 02:36 PM
Shmee
12-22-12 11:27 AM
solowlex
11-27-12 11:09 AM
Mike1970
03-05-11 10:09 PM
Quick Reply: wheel fitment help needed
