92 sc400 codes 14 and 15
Old 02-24-14, 04:26 PM
sc710
sc710's Avatar
Question 92 sc400 codes 14 and 15
So i have been searching all day and im stumped. I started my car this morning and its running fine. Go to leave for work put it in gear and it has a misfire. so turned it off did some searching checked the codes and got 14 and 15. seen similar problems where the car doesnt run but mine still does and if i let it sit for a bit start it and it runs fine again for a few minutes or you put it in gear then misfire. im really confused has been running no problem then this. any help would be appreciated thanks
Old 02-25-14, 06:57 AM
sc710
sc710's Avatar
really? nobody has anything. i need help this is my only car so without it i cant get to work. please help
Old 02-25-14, 07:02 AM
SC400slide
In Recovery Mode
SC400slide's Avatar
14 = Igniter signal, 15 = Ignitor signal. I bet that your coils (or ignition coils) went. While the vehicle is on idle, unplug one at a time. If the idle changes, you know that coil is good. There are two on your SC.
Old 02-25-14, 07:15 AM
sc710
sc710's Avatar
ok thanks thats kinda what i was thinking but since this is my first sc i wanted some imput before i spend money on something i dont need. last night i started it drove 3 miles to town started missing when i got there. then on the way back it got way worse. crazy cause it drives fine all the time parked it for 2 days to fix my headlights and replace the front upper support and hood hinges now this lol.. i give that a try i appreciate it.
Old 02-25-14, 07:48 AM
RandC
RandC's Avatar
It's also a good idea to check for a faulty ground connection on the engine block. I believe the ignition and efi grounds are connected on the back of the left cylinder head.
Old 02-25-14, 07:49 AM
sc710
sc710's Avatar
So went out started it ran fine had to wait about 5 minutes with it running till it started misfiring. Tried unplugging the coils and the car died both times. Not sure what that means.
Old 02-25-14, 07:50 AM
sc710
sc710's Avatar
ok ill check the grounds
Old 02-25-14, 01:30 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
That means your coil packs are good. Moving on to different things. Check the grounds like mentioned.
Old 02-25-14, 09:39 PM
sc710
sc710's Avatar
been trying to search for grounds. did they decide to hide a few? someone said that there might be moisture in the gas tank cause when missing it runs fine for a minute then misses then fine for a minute then misses again.. or could it possibly be my altenator going out on me and not sending the right amount of juice to the system?
Old 02-26-14, 07:07 AM
SC400slide
In Recovery Mode
SC400slide's Avatar
Grounds.
https://www.clublexus.com/forums/sc-...nds-sc400.html
https://www.clublexus.com/forums/per...for-sc400.html
Old 02-26-14, 07:38 AM
sc710
sc710's Avatar
thanks for the links. the pictures wont come up anymore so i cant really see where they are. but i guess ill do some digging around under the hood again today.
Kingunis
12-12-15 12:24 PM
Scjunky94
12-04-15 08:51 AM
charger980
13
08-14-13 02:10 PM
LEXZILLA
11-16-11 10:06 AM
C3BlacIce
10-26-11 07:23 PM
Quick Reply: 92 sc400 codes 14 and 15
