Ohlins coilovers
Old 04-07-14, 06:33 PM
  #31
darbs242
darbs242's Avatar
Once you get that's et up it should handle incredible
Old 04-08-14, 07:16 AM
  #32
phm14
phm14's Avatar
Nice hardware. I was able to pick up a used set of these Ohlins DVFs for my 3rd gen Miata track toy, and they do live up. Run a Ohlins designed shock on my mountain bikes as well, and they have been trouble free, with extended service intervals, for 7+ years. You will be ready for some serious track day fun
Old 04-08-14, 11:12 AM
  #33
JT2MA71
JT2MA71's Avatar
Received 1,513 Likes on 656 Posts
Thanks!
I got the whole kit installed finally and may have a chance to test the car out today. The way these are set from OHLINS Japan (I didn't adjust the height or preload yet), the car is now siiting on stock height again. I will adjust it after taking it out for a drive.
Attached Thumbnails Ohlins coilovers-coilinstall2.jpg   Ohlins coilovers-coilinstall3.jpg
Old 04-10-14, 10:30 AM
  #34
JT2MA71
JT2MA71's Avatar
I adjusted the height yesterday, slightly lower than the swift spring/factory shocks combo. My observations so far;
Car stays flatter (also installed hotchkis rear bar)
Less bounce, not that the swift and stock shock combo was, but I believe
that mainly it's because of the adjustable dampening. They're 36 way adjustable, I have the fronts at 25 and rears at 20. Where do you guys have yours at? Regardless of coilover brand of course.
Old 04-10-14, 10:48 AM
  #35
ULTSISF
ULTSISF's Avatar
Looks nice, I have my dampening 12F 14F counting from stiff to soft I love it. Once wheels arrive I will adjust 2 more turns towards stiff 10/12.
Old 04-10-14, 05:27 PM
  #36
JT2MA71
JT2MA71's Avatar
On thanks! I am at around 10f and 15r, stiff to soft.
Old 07-28-14, 11:08 AM
  #37
XpediencY
XpediencY's Avatar
How do you like them seeing that you're a couple months in now? I'm thinking about getting a set.
Old 07-29-14, 10:34 AM
  #38
Nigel-JDMParts
Nigel-JDMParts's Avatar
You guys can also consider the SARD KW Suspension.
SARD Racing are using the KW hardware, and SARD have R/D for the ISF and set it up in the SARD Spec.
SARD are using different oil, damping, value and spring rate than the KW V3 or Club Sport.
I've a few customer using the SARD Spec KW Suspension on their Toyota 86 (Scion FRS), IS350 and everyone is very happy!! In Japan, Japanese have compare the SARD Spec V.S. the KW V3 and Club Sport and they are definitely not the same thing.
Old 07-29-14, 10:38 AM
  #39
JT2MA71
JT2MA71's Avatar
No complains here. Worth the money IMO.
Old 08-13-21, 11:15 AM
  #40
Jwconeil
Jwconeil's Avatar
I just stumbled upon these ISF specific Ohlins coils. These may be an excellent choice for budget conscious buyers. Sadly, they are out of stock.
https://www.springrates.com/ohlins-r...SABEgIjXPD_BwE
Edit - I just saw they have the same spring rates as the IS350 version, 10/6K. Probably ok for street, but higher rates would be advantageous for track.
Old 08-13-21, 08:08 PM
  #41
ChpEng
ChpEng's Avatar
Interesting that this retailer claims ISF fitment specifically for part number LES Mi00S1 while Ohlins USA does not. That kit retains the rear's factory "standard top mount", the conical cylinder between the chassis seat and top of the spring.
Here is what Mike @ Figs had to say about LES Mi00S1 fitment in another thread.
Old 08-14-21, 08:24 AM
  #42
Jwconeil
Jwconeil's Avatar
Thanks. If something seems to good to be true, it probably is. A high end ISF suspension for 2500 would have been nice .
bigwes
Suspension and Brakes
22
09-03-14 09:44 AM
KhoaNguyen
20
09-07-12 12:26 AM
kaldES98
24
10-26-09 04:06 PM
uenolove
16
06-06-07 10:46 PM
persian451
08-04-03 05:08 PM
Quick Reply: Ohlins coilovers
