burning oil on a is350
Old 03-21-14, 09:29 PM
racsos222
racsos222's Avatar
Default burning oil on a is350
Hello everyone,
been lurking on this forum for awhile gaining knowledge from all of you smart folks!
needed some help. I changed the oil on my car and because it was a little colder than normal out, decided to let the oil change go for 8k. I use toyota synthetic 0w20 and was told i could probably go to 10k, so i figured i should be ok.
My concern is that when i drained the oil only 5 quarts came out when i put in 6.5! So this has me a bit worried and upset that i didn't check the oil sooner.
1. is this normal?
2. did it cause any damage not having the full 6.5 quarts of oil in there?
Old 03-22-14, 12:28 AM
jdmSW20
jdmSW20's Avatar
i wouldnt really stress it. that much time driving you have to expect some of it to be gone. but at least you didnt check the oil and only 2 quarts came out
Old 03-22-14, 08:59 AM
Gville350
Gville350's Avatar
How many miles on the motor? Mine with 76k burns ZERO oil.
Old 03-22-14, 09:29 AM
pheonix72
pheonix72's Avatar
1.5qt over 8k miles isnt too bad! Also, that would only put your oil level at the miminum low end so i would not worry too much about it. I would recommend check the level every couple thousand mokes and top the oil off if it makes you feel better.
Old 03-22-14, 02:49 PM
mike33
mike33's Avatar
0w20 is a very thin oil and may burn off faster... Do you really need such a thin oil? The recommended weight is 5w30 and should be good for use in temps below -30...
Old 03-22-14, 07:14 PM
racsos222
racsos222's Avatar
i have 80k on it.
i would be so upset I'm so **** about the car lol
i thought about the weight of the oil as well, but the new IS350's are spec'd with that oil and from my understanding the engine has not changed at all? I also read multiple threads over at bob is the oil guy and the difference from a 20 weight to a 30 is not much. I decided to use the toyota 0w20 because it has a bunch of moly and is supposed to help with cold starts. I am going to go back to 0w30 and see how much it burns.
simonasj
07-28-23 01:51 PM
lilativan
IS - 1st Gen (2001-2005)
01-09-19 12:01 PM
IamLexus
07-30-16 06:18 PM
amerquresh
05-11-12 06:39 PM
swheat
06-29-09 06:52 PM
Quick Reply: burning oil on a is350
