B pillar part number?
Old 03-31-14, 08:30 AM
Alexbenz
Alexbenz's Avatar
Default B pillar part number?
I was trying to order the B pillars for my 97 es300 but the parts associate was giving me a hard time at the counter, apparently he couldn't find the exact part.
It's the pillars on the outside between the front and rear windows. Both sides now are broken. I need both along with any hardware needed, from the looks of it it seems to be clips which i think will come on the new pillars.
Thanks
Old 03-31-14, 10:06 AM
Received 2,712 Likes on 2,297 Posts
75505-33010 - RH moulding
75506-33010 - LH moulding
The clips used are:
75395-33020
75396-33040
The b-pillar trim is no longer available the part is flagged as obsolete. You still might be able to find it on Ebay, if not then either a salvage yard or look on Ebay for aftermarket trim which is a stick-on that covers the factory part.
edit - something like this
Old 03-31-14, 10:18 AM
Alexbenz
Alexbenz's Avatar
The clips used are:
75395-33020
75396-33040
i just need to clips , do they have those in stock still?
Also that ebay link i saw earlier when i searched on ebay but does it replace the factory ones or does it stick ontop of the factory ones?
Old 03-31-14, 10:24 AM
Sticks onto your existing ones. The clips I'm not sure you'll have to call a Toyota or Lexus dealer. But if the b-pillar trim is no longer available then the clips might not be either.
Old 03-31-14, 11:06 AM
Alexbenz
Alexbenz's Avatar
thats sorta dumb, so in this case what do they expect to repair or fix it?
Old 03-31-14, 11:29 AM
Alexbenz
Alexbenz's Avatar
lexus2000 thanks...i called the dealership and they sell the clips but it's a special order...
Old 04-02-14, 10:32 PM
Alexbenz
Alexbenz's Avatar
Got the clips today and tried to install them on one side only to find out the bracket for the clips is broken...2 of the 4 are broken...trying to come up with a solution now.
Old 04-03-14, 11:02 AM
Those pieces are very fragile, I've tried removing them from cars at the salvage yards and they almost always break. This stuff is probably your best bet, put a dab of it on the broken area and on the clip. This might also work.
Old 04-03-14, 01:41 PM
Alexbenz
Alexbenz's Avatar
what part of it would you suggest i use glue or mounting tape? unless i glue to clips to the mounting spots because half the mounting bracket is broken off
Old 04-03-14, 03:31 PM
That's what I'm thinking. However gluing plastic is iffy can't say if it would hold long term. But what choice do you have?
Old 04-03-14, 09:43 PM
Alexbenz
Alexbenz's Avatar
Looks like this.
Old 04-08-14, 09:40 AM
Power6
Power6's Avatar
Oh man I am glad I bought one of each side of these! They must have just run out of these not long ago. The original ones peel.
Old 06-11-14, 09:40 PM
Alexbenz
Alexbenz's Avatar
i'm going to try the dealership here and also a wrecking yard but for now i used 3m strong double sided tape and it's on there but who knows....no idea why they'd stop making a part for whatever reason.
Old 06-12-14, 08:50 AM
PFB
PFB's Avatar
I was curious to see if those parts are still available in Canada, which is where I am. So I called the Lexus dealer here in Montreal, and he advised me that those parts are definitly still available, and that they come with the clips.
In fact I told them that someone in Californa was told that they have been discontinued, so he looked it up On line and said there are 50 of them sitting in a Lexus California distribution center.
Go figure.
Phil
Old 06-12-14, 05:07 PM
Alexbenz
Alexbenz's Avatar
Yes still available at southbay Lexus... retails 105 each. Didn't think they'd discontinue a part like that without having a solution to either fixing it or replacing it with another part.
Brownd3max
08-09-18 07:56 PM
Stylz79
RX - 3rd Gen (2010-2015)
10-08-16 01:48 PM
Greg5OH
11-12-13 01:58 PM
CJHYBRID
Hybrid Technology
07-19-13 05:02 AM
Murong
03-11-12 02:41 PM
Quick Reply: B pillar part number?
