GS450h rear battery bracket in a GS350
Old 04-30-14, 08:26 PM
rjk
rjk's Avatar
Default GS450h rear battery bracket in a GS350
Anyone know if this would work? I'm going to be wiring up a dual battery kit, and I'm wondering if I could use the battery bracket out of the 450h to trunk-mount the rear battery in my 350. I don't know if the same mounting points are available or if I would need to replace the trunk liner as well, or what.
Also going to be mounting an air compressor for my train horn, need to figure out where to put that.
Old 04-30-14, 08:53 PM
rjk
rjk's Avatar
This is the thing I'm referring to:
Is there a cover for it, or would I be able to use the trunk liner from a 450h in my 350 as well?
Old 04-30-14, 08:58 PM
rjk
rjk's Avatar
There's also this one, which seems dead center in the trunk. Does it go in the spare battery hole? It's designed for the cars that have the active suspension option:
Old 05-01-14, 06:53 PM
rjk
rjk's Avatar
Bump... can anyone perhaps provide pictures of the 450h trunk with the covers and stuff removed? The left cover on my 350 has enough room for another battery, but I don't see any bolt holes for a mounting bracket.
Old 05-02-14, 04:58 AM
uberEJ
uberEJ's Avatar
you would need to drill new holes. if you take out the spare tire or cut some of that plastic that holds the spare tire in place you may have room.
under that left cover is only big enough to fit a small battery... that is if your trying to cover it too.
hope that helps. question though... why do you want to put another battery in?
Old 05-02-14, 05:06 AM
rjk
rjk's Avatar
Thanks for your help. It's going to run an air compressor for my train horns. I just need to figure out the best way to mount everything and route some heavy wire up to the front along with some air hose.
Old 05-02-14, 06:54 AM
uberEJ
uberEJ's Avatar
why not just wire from your stock battery though? you can always upgrade the batter if you feel its too weak. always a good mod for accessories =)
Old 05-02-14, 07:49 AM
rjk
rjk's Avatar
Mainly because I don't want to be stranded with a dead battery if the compressor is running too long, and also because the rear battery allows me to self-jump in case the main battery dies. I'm using Odyssey batteries currently.
Old 05-02-14, 08:31 AM
uberEJ
uberEJ's Avatar
ah I see.... what size is the compressor shouldn't have to be that big to blow a train horn should it? I have a viair95c that powers the compressor on my ruckus. u can air in air out for hours before the battery drains.... that battery is super small too.
Old 05-02-14, 08:45 AM
rjk
rjk's Avatar
I have one of these suckers: http://www.ebay.com/itm/310922617414
30 amps continuous, and I might not want my car running the whole time.
Old 05-03-14, 07:25 AM
rjk
rjk's Avatar
I went ahead and ordered a generic bracket off ebay, because it was cheaper and much stronger. Now I just need to figure out how to mount it and how to run some wire and hose.
Old 05-03-14, 11:34 PM
02REX
02REX's Avatar
now that i got my GS, i wanted to get an air set up and go VIP. but i didnt know that one of the concerns was the compressor running constant and killing the battery. do most guys run a second battery for their air set ups?
Old 05-04-14, 07:14 PM
rjk
rjk's Avatar
Well it would only be a problem if you were going to be running it a lot with the car off.
Old 05-04-14, 09:39 PM
XxGoKoUxX
XxGoKoUxX's Avatar
No, the compressors do not run on constant. They turn off when the car shuts off, you hook them up via relay to the compressor's system (Accuair anyways).
They only turn on if you air up while the car's off, and while it's on, it's on for maybe 3-5 seconds and it shuts off.
ronnen
07-15-18 10:03 AM
Tantrix
Hybrid Technology
05-28-18 09:18 AM
keldon595
ES - 6th Gen (2013-2018)
05-11-18 11:47 AM
Moarpower
01-28-18 03:49 PM
JDKane527
12-21-11 06:09 PM
Quick Reply: GS450h rear battery bracket in a GS350
