Help needed - door mouldings
Old 05-01-14, 03:03 AM
koksik
koksik's Avatar
Default Help needed - door mouldings
Hi, Im looking for help from You guys... I need to get lenght of all door mouldings from lexus ls460/600 so each - rear , front and little wing pieces. Its urgent.
Thanks in advance
Old 05-01-14, 06:31 AM
sktn77a
sktn77a's Avatar
What exactly do you want? The measurements? The parts? What do you mean by "door moldings" - silver trim, rubber seals, ?
Any parts you need urgently will pretty much need to be obtained from the local dealer.
Old 05-01-14, 06:40 AM
Valley101
Valley101's Avatar
Default Door Mouldings
If you are talking about the mouldings that go on the doors to help prevent door dings Lexus does not sell them. They are aftermarket only.
Old 05-01-14, 07:29 AM
koksik
koksik's Avatar
Plastic and chrome trim on the bottom of the doors and front wing.
I need measurements of them in in or cm , how long they are
Old 05-01-14, 08:49 AM
lbintab
lbintab's Avatar
Fyi it's different for a long wheel base compared to the standard one. Which one do you need?
Old 05-01-14, 09:04 AM
koksik
koksik's Avatar
For LS600hl
But for normal one as well just in case
Old 05-01-14, 03:30 PM
koksik
koksik's Avatar
anyone? LS460L and normal as well
Old 05-01-14, 06:11 PM
jlawr
jlawr's Avatar
Why would you need both? Did you damage someone's? Are you trying to fix it yourself before they find out?
Old 05-02-14, 01:06 AM
koksik
koksik's Avatar
I just want measurements....
Old 05-02-14, 02:15 AM
slimjimtel
slimjimtel's Avatar
They won't fit an IS250/350/F, if that is what you're trying to do.
Old 05-02-14, 02:16 AM
lbintab
lbintab's Avatar
I don't think I'm the only that won't go out of their way to answer this question. The feeling I'm getting is that you're a little cold on your request and vague on the the reason why you need that info. Most will be more interested to go out to their garage with a tape measure for you if they knew the reason why. Just being honest.
Old 05-02-14, 02:25 AM
koksik
koksik's Avatar
Thx for reply, Im not cold, I can tell the reason, no problem.. just dont like when Im asking for simple help, and Im getting hundred questions..
I want use them on my car, want make some mods to make them fit on my IS, just want see is my plan will work, thats why I need those measurements, before I buy those parts.
Will be great if You can check that for me.
inrisls400
04-19-22 04:08 PM
93sc400nm
Performance & Maintenance
11-20-16 08:53 PM
hoolcat
11-25-03 12:42 AM
Quick Reply: Help needed - door mouldings
