Paddle Shift Manual Won't Work?
Old 05-19-14, 07:01 AM
finalhope
finalhope's Avatar
Default Paddle Shift Manual Won't Work?
So I put my IS350 F Sport on manual mode and tried moving the gears up and down with shift **** or paddle shifters and both don't work? Am I doing something wrong? The gears are not shifting at all when I click on the paddle shifters or move the shift **** on manual mode.
Old 05-19-14, 07:14 AM
Mr_VFS1
Mr_VFS1's Avatar
That is really strange. I have never heard anything like this. Did you try turning the car off, back on, putting in sport mode, then switching to manual? Try driving in sport + automatic then switching to manual.
Old 05-19-14, 07:35 AM
JGard18
JGard18's Avatar
Were you moving?
Trying to shift while stopped isn't going to yield great results.
Also, was the car cold? Often times when my car isn't warmed up, it doesn't upshift when I tell it to
Old 05-19-14, 07:52 AM
corradoMR2
The pursuit of F
corradoMR2's Avatar
^^^ exactly, it won't shift until proper operating temp is reached.
Old 05-19-14, 08:08 AM
JCWong
JCWong's Avatar
or it has to be within optimal speed for the gear you want to change into?
Old 05-20-14, 04:13 AM
finalhope
finalhope's Avatar
Well I wasn't really moving because I was afraid to since I don't know how to drive manually lol.
Old 05-20-14, 05:27 AM
Mr_VFS1
Mr_VFS1's Avatar
Well you can't switch gears if you aren't moving... It's as useless as using the gas pedal when the car is off. As for not knowing how to drive it, play around with it. I didn't know how to either and I learned really quickly. All you have to do it drive in auto with the dash displaying the gears and just watch it a little to observe where it upshifts/downshifts.
Old 05-20-14, 05:50 AM
Aeromotive
Aeromotive's Avatar
I don't have the IS yet but can't you switch gears while you're stopped? I think that's what OP was doing...
I know my F30 335 allows you to do so, just like in a real manual transmission!
Old 05-20-14, 06:40 AM
finalhope
finalhope's Avatar
Correct, my 07 IS250 allowed me to do so. Something wrong with my IS350 or is it normal to not be able to switch gears while you're stopped?
Old 05-20-14, 06:44 AM
Mr_VFS1
Mr_VFS1's Avatar
It's normal. You can't switch gears while stopped in the 3IS.
HeadShot (02-18-23)
Old 05-20-14, 10:53 AM
TheShaddix
TheShaddix's Avatar
What's there to be afraid of? it'll shift for you even if you don't shift in time. When cruising, shift (manually) around 2.5-3k rpm, when going full throttle, shirt right before it reaches redline. Do this a few times and you'll laugh at your initial fears. And about the 335i, it allows you to shift from 1 to second when stopped, but that's it. If you shift to 3rd, it will drop down to second or so when you start moving, so it's not actually shifting, just changing numbers on the dash.
Old 02-14-23, 09:39 PM
Jdouglas99
10th Gear
Jdouglas99's Avatar
sorry to bring up a dead thread, did you ever happen to find out the cause of this issue. Neither my paddles nor shift **** respond to gear change. Itll show I switched to manual on my dash with the current gear but no response. Thanks!
Old 02-14-23, 10:03 PM
05RollaXRS
05RollaXRS's Avatar
Received 2,417 Likes on 1,741 Posts
It was a couple of posts down. He was not even moving when he was expecting the paddle shifters to shift through gears. You need to be driving at 15 - 20 mph or over to shift out of 1st gear shifting up.
Old 02-14-23, 10:06 PM
Jdouglas99
10th Gear
Jdouglas99's Avatar
Ah gotcha. Well I'm still at a loss for the reasoning for my issue. Any help would be appreciated. Fuses or relays to check? Clock spring is good id assume. I have cruise and horn functions.
Old 02-15-23, 06:14 PM
ScytheDC
ScytheDC's Avatar
can you post more info on your circumstances rather than having everyone try to guess? Are you also trying to shift while stationary?
Quick Reply: Paddle Shift Manual Won't Work?
