help! Broken oxygen sensor connector (female end, Bank 1 sensor 2)
Old 05-19-14, 08:14 AM
StarGS3
StarGS3's Avatar
Default help! Broken oxygen sensor connector (female end, Bank 1 sensor 2)
My oxygen sensor (bank 1 sensor 2 ) connector (female connector, engine/ecu side) is cracked and the wires pulled out. I tried to source this from a junkyard but no one around me (LI, NY) seems to have the car.
Any ideas on where I can get a replacement connector to splice in?
Old 05-19-14, 08:28 AM
iToaster
iToaster's Avatar
The part number is 90980–11028, you can get one from any Lexus or Toyota dealer for less than $10.
Old 05-19-14, 08:55 AM
StarGS3
StarGS3's Avatar
Thanks, very helpful! Do you know if this part comes with the metal inserts and rubber grommets that I'll need to rebuild the plug or is it just the plastic housing?
Old 05-19-14, 09:31 AM
iToaster
iToaster's Avatar
It's just the plastic housing. You should be able to remove the pins from your old connector and reuse them if they are undamaged. If you need them, 82998-12440 is the part number for the wires with the female pins on the end of them for that connector, but you would need four of them and they're each almost as expensive as the plastic connector.
Old 10-18-17, 07:35 AM
AndrewG
AndrewG's Avatar
82998-12460 is the part number for the gold plated pins. 82998-12440 is for the silver pins. Hope this helps.
Old 10-19-17, 06:06 PM
Alphaman19
Alphaman19's Avatar
I've got them from an old gs400 motor that I pulled and is about to go to the scrapper. Let me know and I'll snip them off and send them to you.
denIS200
09-11-16 07:07 PM
SMUChris
12-17-12 03:50 AM
Bourke
12-02-12 07:57 PM
chenxingha
RX - 1st Gen (1999-2003)
06-07-11 09:03 PM
lexusben
03-21-11 11:05 PM
Quick Reply: help! Broken oxygen sensor connector (female end, Bank 1 sensor 2)
