CA NEW CP 8.5.1 86mm Pistons Coated with upgraded Wrist pins!!
Old 06-24-14, 08:57 AM
8052JZ
8052JZ's Avatar
Default NEW CP 8.5.1 86mm Pistons Coated with upgraded Wrist pins!!
2JZ 86mm 8.5.1 Compression CP pistons for sale. Part# SC7459 New Never Been Ran. I have nearly 1100 into these pistons. they retail around $850 +/-
-They have been Thermal barrier coated to better protect the pistons. Coast me about $300 just for the coating from Extreme Performance Heat Coatings.
This is from there site.
"Thermal Barrier Coatings
Thermal Barrier Coatings (TBC’s) are designed to reduce the movement of heat. In some instances, such as exhaust systems, you want to keep the heat within the part. In combustion chambers you want to use the heat generated by combustion to push down on the piston rather than bleed off into surrounding surfaces. Due to continued testing we are learning that simple thermal barrier action is not the only characteristic that is important. In fact certain TBC’s will move an engine into detonation. TBC coatings can be made from a variety of materials. Ceramics get the most attention, though there are other materials that are superior in specific applications. The proper choice is critical to the overall function of the coating."
-The upgraded wrist pins are the thicker and much stronger CP wrist pins that are an "upgrade" option when ordering these pistons directly from CP. An extra insurance policy using thicker and much stronger pins. I paid about $150 Part# 866-2250-20CP3C
ASKING $950 Shipped on these Pistons. You wont find a better deal than this for a great set of pistons with upgraded pins along with being coated.
The coated pistons
Original CP wrist pins next to one of the new upgraded wrist pins.
Last edited by 8052JZ; 06-26-14 at 10:51 AM. Reason: Part numbers added, added pics
8052JZ is offline
Old 06-24-14, 12:37 PM
lexforlife
lexforlife's Avatar
if you ever decide to sell pins sep please lmk as i have brand new cp reg pins can send back to you if needed , of course i will pay for the upgraded ones
lexforlife is offline
Old 06-24-14, 07:29 PM
blacksc
blacksc's Avatar
bummer lol if these were only .5 bigger. i could always just buy new but im hoping to get a deal like this
blacksc is offline
Old 06-26-14, 07:37 AM
8052JZ
8052JZ's Avatar
Bump added pics. LexforLife id like to keep them together for now. I will let you know if I decide to part.
8052JZ is offline
Old 06-30-14, 08:13 AM
8052JZ
8052JZ's Avatar
bump need to move as soon as possible...
8052JZ is offline
Old 07-09-14, 01:54 PM
8052JZ
8052JZ's Avatar
Bump it up..... send some offers..
8052JZ is offline
Old 07-21-14, 02:30 PM
8052JZ
8052JZ's Avatar
To the top! Still have these!
8052JZ is offline
//LRD
Florida Lexus Club
674
07-01-13 01:04 PM
JeffTsai
SC400 / 300 Classifieds
01-05-12 03:23 PM
//LRD
Florida Lexus Club
79
06-13-11 07:07 AM
TomLee
General Classifieds
11-06-08 05:55 PM
Quick Reply: CA NEW CP 8.5.1 86mm Pistons Coated with upgraded Wrist pins!!
