So I took my 350 on a canyon-type road today
Old 06-29-14, 03:30 PM
Gville350
Gville350's Avatar
Why even compare the two? Not even similar at all!
Now, if you do want to make your 2IS handle better, you're on the right track; sway bars, coilovers to lower center of gravity, sportier seats (I agree the 2IS don't provide any bolster support at all in the corners), and most important...better tires. I'd say the $400+ for the steering ecu could better spent for better tires, lighter wheels, or better coilovers.
Old 06-29-14, 03:47 PM
redspencer
OG Member
redspencer's Avatar
Originally Posted by Re3iRtH
Wow you have to get the whole ECU swapped just for steering.
For anyone that has done this, do you think it was a good buy?
Sounds like an easy plug and play mod if the results are worth it.
The 2012 ISF steering ECU is well worth the $$. I'd buy it all over again if I had to.
Old 06-29-14, 05:29 PM
ISland350
ISland350's Avatar
I will get the rear sway and chassis brace. Thanks
The car came with suspension, but the last owner wasn't
sure what brand it was (he wasn't sure of a lot).
Is there a simple way to tell?
Take pics thru the rear wheel for us...Did he say coils or Springs?
Old 06-29-14, 07:57 PM
getafewliv
getafewliv's Avatar
I've got the steering damper and rear sway bar on the way. May eventually get the ISF steering ECU as well. I hate doing the pedal dance, I always forget. I believe the new ECU fixes this issue.
Old 06-29-14, 08:24 PM
mike33
mike33's Avatar
An isf steering ecu will not eliminate the "pedal dance". You would need to get an abs/skid control ecu from a 2007 or newer isx50. I purchased a used one on ebay for $110, and no more "pedal dance". The 2007+ would be part # 89540-53290 and will have a VT on the label. The 2006 is part # 89540-53251 and has a V5 or V9 on the label.
Old 06-30-14, 11:51 AM
Gville350
Gville350's Avatar
^Good info! Using the P/N, I immediately went to ebay and found this : http://www.ebay.com/itm/LEXUS-IS250-IS350-ABS-TRAC-VSC-COMPUTER-SKID-CONTROL-TRACTION-89540-53251-/161192603875?pt=Motors_Car_Truck_Parts_Accessories&hash=item2587d3f0e3&vxp=mtr
Old 06-30-14, 01:05 PM
mike33
mike33's Avatar
That one is from a 2006, and would still require the pedal dance...
This is the one you would need:
http://www.ebay.com/itm/Lexus-IS350-ABS-Skid-Control-Module-8954053250-8954053251-8954053290-/300872241520?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3AIS350&hash=item460d621170&vxp=mtr
Old 06-30-14, 01:22 PM
Re3iRtH
Re3iRtH's Avatar
Only reason I am comparing is because its the car I dailied for the last 3+ years and
I need to justify its replacement if I am not to purchase a 2nd vehicle
Old 06-30-14, 01:30 PM
Re3iRtH
Re3iRtH's Avatar
I will definitely take pics and post.
All I know is it has Volk racing wheels 19" and Falken tires. He didnt even list the suspension in the ad, until I drove it he casually mentioned that it had after market suspension. I want to say springs but don't know for sure.
Old 06-30-14, 10:47 PM
Re3iRtH
Re3iRtH's Avatar
I ordered the underbody x-brace and rear
sway bar, among minor interior stuff.
Just to make sure.. both the chassis brace and rear
sway can be installed together? One doesn't
interfere with the other is that correct..
Cheers!
Old 07-01-14, 03:31 AM
redspencer
OG Member
redspencer's Avatar
Cheers!
Yes, both can be installed together with no issues.
I also recommend you getting a front sway bar sometime in the future as you'll notice you'll have excessive roll on the front end while the rear end remains planted to the ground, especially since you plan on doing canyon runs.
Old 07-01-14, 02:40 PM
todd4566
todd4566's Avatar
I had the F-Sport rear sway bar on my 350.. it helped but the car still had more roll than I prefer. I would recommend some coil overs in addition to the front and rear bar if you really want to improve handling. I had planned on doing the same to my 350 but decided to jump ship and get an F.
Old 07-01-14, 03:03 PM
Re3iRtH
Re3iRtH's Avatar
May I ask the year and specs of your F, and how much you payed?
Only one used IS-F for sale in my state, its a '12 with around 12k miles,
and he wants about 52k$ with some bolt ons already installed.
Old 07-01-14, 04:13 PM
FSportIS
FSportIS's Avatar
S2k is in different class. Way lighter, way smaller, 2 doors, way more agile. s2k and Miata are damn good in autocross/track.
The IS350 is a balanced machine that is GOOD AT EVERYTHING but NOT GREAT AT ANYTHING. IS350 got the luxury but not top luxury like the LFA. It got the power but not GT-R power. It got good handling but not like Porsche. It got comfort but not like a Camry. It got ok mileage but not like a hybrid. It got some mods but not like the BMW, Evo, Sti etc It got top notch reliability though.
Old 07-01-14, 04:45 PM
Mike_1GO
Mike_1GO's Avatar
Well said!
OP, with those lighter Volk wheels youre already on the right track! I wish we had aftermarket 2 piece rotors to replace the heavy front stock rotors (25 lbs) this would help a lot with unsprung weight
Quick Reply: So I took my 350 on a canyon-type road today
