Build Threads Details on Club Lexus 2IS owner vehicles
Lexus IS250 to IS350 M/T conversion
Old 07-03-14, 11:25 AM
Sffd103
Fire Slayer
Sffd103's Avatar
Have you thought about adding an F Sport short shifter? I added that to my manual transmission and it made the throw so much less. Consider that.
FrictionSc (08-12-17)
Old 07-03-14, 12:10 PM
speedstar
speedstar's Avatar
Awesome! More push for me to start mine
Old 07-03-14, 03:40 PM
plankton07
plankton07's Avatar
F sport SS will be installed next week. Looking forward to it =D
Old 07-03-14, 04:37 PM
Gville350
Gville350's Avatar
Major props for doing the engine swap! Now, can you go into greater details for us here on what exactly was swapped in your car and if you are getting any CELs or warnings or anything?
Thanks!!!
Old 07-05-14, 07:04 AM
ilv1004s
ilv1004s's Avatar
iv done the swap
and theres no CEL no codes
Old 07-05-14, 07:39 AM
jsh139
jsh139's Avatar
This is awesome. I can only imagine what a manual trans 350 would feel like to drive. Good work!
Old 07-05-14, 01:43 PM
rawr2is250
rawr2is250's Avatar
Wow amazing work! you should do a full write up on this!
Old 07-05-14, 03:01 PM
mikellucci
mikellucci's Avatar
Originally Posted by ilv1004s
iv done the swap
^I thought you did the actual 6spd gearbox into an auto is350? Wasn't there a lot of pins to rewire to get rid of all the Codes from the ECM?
Old 07-05-14, 08:01 PM
ilv1004s
ilv1004s's Avatar
yeap
this is my brothers car
its a manual IS250
then we put a 2011 IS350 runing gear into it
took out the autobox and bolted up the MT box
no rewire or anything needed
other than the wiring for the gearbox and reverse sensor input
and the ECU has to be reflashed to delete the autobox off the ecu programing
Old 07-06-14, 08:55 AM
pepos
pepos's Avatar
Congrats, an exeptional mod.
I have a 250 M/T supercharged running beautifully for 30.000 miles now.
Fidanza flywheel along with the Spec 2 clutch go along like a glove.
Install a quick shift and it will change the stick's distance to half.
Congrats again.
Old 07-06-14, 09:16 PM
plankton07
plankton07's Avatar
Nice a supercharger. I was thinking of supercharging the 3.5L but not sure if the box can handle that much power. The car loses enough traction already at the moment...
Old 07-07-14, 07:08 AM
NYKnick101
NYKnick101's Avatar
yeap
its a manual IS250
So I am confused here and need some clarification. So you are saying that the IS350 engine is a direct swap to the IS250 with no/minimal rewiring. What I'm reading is that you had a M/T IS250 took out the 4gr engine, installed the 2gr engine from the 350 with A/Tand it was a direct swap other than the gear box wiring. Did you document any of the work done? Sorry to be a skeptic but something is a little off
Where did you reflash the ECU? I thought the toyota N/A ECU's couldn't be reflashed
IF it is true, this opens up alot of options for modding an IS250 since the 250 is the only one that can accept an LSD from earlier models.
Old 07-07-14, 07:22 AM
An2ny
An2ny's Avatar
Wait; so is it really that easy?
What other parts are needed? I am guessing, every single component from the engine bay, radiator etc. Are the 350 engine mounts at the same location any drilling reinforcement needed?
Any parts relocation needed to fit it with the 6-speed transmission?
I am sure that the 250 differential will be ok for a while with the extra HP so I wouldn’t worry about that.
Anything else?
Old 07-07-14, 05:20 PM
ilv1004s
ilv1004s's Avatar
this is a basic run down
we used everything out of a 2011 is350 wreck which i bought for a dirt cheap price at the auctions
the whole is350 wiring was used everything down to the nav and audio etc
so even though the car is a 2006 IS250
the way we went about it
reshelld the 2011 IS350 into the 2006 IS250
and then took the MT box off the 250 motor
and bolted it up to the 350 motor
yes the ecus can be reflashed but we are not in the USA
Old 07-08-14, 06:32 AM
SubieChik
SubieChik's Avatar
I've always thoguht the M/T in the 250 could not handle the 350 power....at least that's what I have been told.
Awesome swap though!
Quick Reply: Lexus IS250 to IS350 M/T conversion
